How to view various info boxes on institute/branch dashboard?
  1. Login on web.edprime.co using your registered email ID and password.
  2. Scroll down on institute dashboard and click the slider button on the right side to view various informational graphs and lists.
  3. Go to switch profile option and select any branch.
  4. Again, click on the slider button on the right side to view branch data in form of various graphs and lists.
    • How to customize institute and branch dashboard display ?
      Go to institute or branch level dashboard. Scroll down and click on custom display option given on right side. Rearrange the given headers as per your requirement on the popup window. Scroll at the bottom on this popup window and click on save to ...
    • How to Register a New Branch?
      Go to the Branch under the Master module on the institute level.  Click on Branch Registration  Click on Add branch  Fill in all the required detail  Click on Submit button  An Email would be sent on a registered Email ID  The user needs to click on ...
    • How to view Online Transaction?
      To view Online Transaction, hover the cursor on the Student module after that look for Student Enrollment, then please click on Online Transaction. Once you click on Online Transaction you would be redirected to the Transaction Listing page. By ...
    • How to open admission for the branch?
      Go to Configuration under Settings in Masters Module,  Click on Online Registration and then Admission Open for Branch  Tick Mark Yes under Show Branch and Hit Submit.
    • How to search branch user listing and update branch user details?
      Click on Employee Under HRMS Module,  There you will get the branch user listing,  Select which branch user you want to update and click on the Pencil Icon under Action,   Make required changes and Click on Save Profile.
