Let's explore how to publish marks step by step:
Step 1: Begin by securely logging in to your EdPrime account.
Step 2: Navigate to the 'Examination' tab and locate the 'Examination' section.
Step 3: Within the 'Examination' section, find and click on 'Publish Marks Settings'.
Step 4: Here, you will be taken to the ‘Publish Marks Settings’ page. Here, Select Term > Select Exam > Select Classes(s)-Section(s) for which you wish to publish marks.
Step 5: Choose the date for publishing marks using the 'Publish on' option.
Step 6: Utilise the 'Hide Marks for Fee defaulters' feature to hide marks from students with due fees.
Step 7: Select the desired ‘Instalment’ and choose the students individually or altogether in ‘Student’. This will restrict external visibility of marks to all the fee defaulters.
Step 8: Press ‘Add Icon’ to publish multiple marks.
Step 9: Repeat the same procedure and press 'Submit' to finalise publishing the marks externally!
Note: The marks can only be published by the branch administrator. of any mistakes are found after publishing the marks externally, raise a ticket or contact support at +91 86963-29632 / support@edprime.co for assistance. It is suggested to ‘Verify Scholastic Marks’ after you ‘Input Scholastic Marks’ to avoid any errors.
Students can now conveniently access their academic performance on their EdPrime accounts. Empower your students with timely insights into their progress using EdPrime's intuitive features.
